	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/32" />
	<updated>2021-08-29T18:05:24+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/32</id>
		<author><name><![CDATA[tracer55]]></name></author>
		<published>2021-08-29T18:05:24+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2784#p2784</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2784#p2784"/>
		<title type="html"><![CDATA[Re: Outdoor Camera Mounting]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2784#p2784"><![CDATA[
OK so +2 years give or take  <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_surprised.gif" width="15" height="17" alt=":o" title="Surprised">  and I'm still considering buying the StereoPI for this outdoor build. I actually want to build it into a weather station.<br>Anyone since then has a long time outdoor setup running and can tell me about his/her experiences to help me decide to buy this or not?<br><br>What I mentioned about the red shift and white images those are caused by the NoIR pi camera module which is sensitive for bright daylight and would need an additional IR lense.<br><br>Sadly there is no PI CAM v3 yet so if I decide to do this build I stuck with the old v2.1.<br><br>Also I would still like to combine the 2 images into 1 single stream because I planning to add the stream into MotionEYE.<br><br>Were there any developments made in this regard? <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_wink.gif" width="15" height="17" alt=";)" title="Wink"><p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=91">tracer55</a> — Sun Aug 29, 2021 6:05 pm</p><hr />
		<updated>2020-10-23T09:45:33+00:00</updated>
		<published>2020-10-23T09:45:33+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2309#p2309</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2309#p2309"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2309#p2309"><![CDATA[
Hi  tracer55,<br>In the StereoPi software (specific SLP image) we are using native RaspiOS camera-related features. I.e. raspivid tool, but not v4l2. BTW, as I know the latest V4L2 use MMAL under the hood and interact with the camera the same way as <em class="text-italics">raspivid</em>. We prefer to use this as we have many more options and support from RPF (and even our own, fixed, and compiled from source raspivid version).<br>Your mentioned white nothing and red shifted images on a regular Pi means specific settings you're using. MotionEye is a specific image, and we have no experience with it. <br>To say briefly, if you get reliable solution with the classic Pi, you can repeat it on the StereoPi, but with 2 cameras.<br>As for the 360 degree stream - we can stream two images from two 180 degree cameras. But "stitching" them to the sphere should be done on the receiving part.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Fri Oct 23, 2020 9:45 am</p><hr />
		<updated>2020-10-19T06:58:17+00:00</updated>
		<published>2020-10-19T06:58:17+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2297#p2297</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2297#p2297"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2297#p2297"><![CDATA[
Ok so more than 1 year later I still considering on building this project <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":)" title="Smile"><br><br>Something like:<br><br><img src="https://i1.wp.com/wp.lancs.ac.uk/aurorawatchuk/files/2016/03/ThomasJacquin2.jpg?w=768&amp;ssl=1" class="postimage" alt="Image"><br><br>I will probably not custom build a housing like he did but buy a broken CCTV dome camera and put the PI in it. <br><br>I would be happy if others could share their outside capture experiences with the StereoPI, I planning to run this for years. <br><br>I have a system with an RPI2, V2 camera, weather sensor built into an IP box since many years on my roof, these cameras work PERFECT inside the building however outside things getting weird.<br><br>When it was even a little sun all I got was a big bright white page nothing else so after wasting time on the RPI forum and other places who said oh it's only specific to yours first I completely replaced my OS which was kali linux at the time with the latest 10 Raspbian Buster then I replaced the camera module maybe that is what's causing the issue.<br><br>My motioin conf is:<br><div class="codebox"><p>Code: </p><pre><code>daemon onprocess_id_file /home/cam/motion.pidsetup_mode offlogfile /home/cam/cam/log/motion.loglog_level 5log_type allv4l2_palette 17input -1norm 0frequency 0rotate 90width 720height 1280framerate 30minimum_frame_time 0netcam_keepalive offnetcam_tolerant_check offauto_brightness offbrightness 0contrast 0saturation 0hue 0roundrobin_frames 1roundrobin_skip 1switchfilter offthreshold 1500threshold_tune offnoise_level 32noise_tune ondespeckle_filter EedDlsmart_mask_speed 0lightswitch 0minimum_motion_frames 1pre_capture 0post_capture 0event_gap 60max_movie_time 0emulate_motion offoutput_pictures offoutput_debug_pictures offquality 75picture_type jpegffmpeg_output_movies offffmpeg_output_debug_movies offffmpeg_timelapse 0ffmpeg_timelapse_mode dailyffmpeg_bps 500000ffmpeg_variable_bitrate 0ffmpeg_video_codec mpeg4use_extpipe offsnapshot_interval 0locate_motion_mode offlocate_motion_style boxtext_right %Y-%m-%d\n%T-%qtext_changes offtext_event %Y%m%d%H%M%Stext_double onsnapshot_filename %v-%Y%m%d%H%M%S-snapshotpicture_filename %v-%Y%m%d%H%M%S-%qmovie_filename %v-%Y%m%d%H%M%Stimelapse_filename %Y%m%d-timelapseipv6_enabled offstream_port 8081stream_quality 50stream_motion offstream_maxrate 100stream_localhost offstream_limit 0stream_auth_method 1stream_authentication admin:bigsecretwebcontrol_port 8082webcontrol_localhost onwebcontrol_html_output ontrack_type 0track_auto offtrack_iomojo_id 0track_step_angle_x 10track_step_angle_y 10track_move_wait 10track_speed 255track_stepsize 40quiet on</code></pre></div><br>So now instead of getting a big white nothing I get red shifted picture (at least you can see something). So this is the kind of things I would like to avoid with buying the StereoPI but I would like to see positive reviews first people are using this camera on the open. <br><br>Also is it easy to make a 360 degree stream and feed that into MotionEYE OS like a regular fisheye camera?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=91">tracer55</a> — Mon Oct 19, 2020 6:58 am</p><hr />
		<updated>2019-05-13T13:28:56+00:00</updated>
		<published>2019-05-13T13:28:56+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=106#p106</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=106#p106"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=106#p106"><![CDATA[
We did not mounted StereoPi outdoor, so can not help you with enclosure advice.<br>But our Sergey @Gol has indoor-mounted camera looking at the street. It works 24x7, with auto settings, and we have no problems you mentioned in your link to Pi forum. But we use only stock Raspbian and native raspivid/raspistill for that.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon May 13, 2019 1:28 pm</p><hr />
		<updated>2019-05-13T10:22:04+00:00</updated>
		<published>2019-05-13T10:22:04+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=104#p104</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=104#p104"/>
		<title type="html"><![CDATA[Outdoor Camera Mounting]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=104#p104"><![CDATA[
Hello Folks,<br><br>While waiting on the board, I wonder if there will also be a ready made case which can be bought for outdoor mounting of the camera or we need to proceed with using broken dome cameras such as:<br><br><img src="https://darkbluebit.com/wp-content/uploads/2016/03/IMG_0983-768x576.jpg" class="postimage" alt="Image"><br><br>To build it in. I was thinking on couple of outdoor designs so far, the easiest seems to be a high diameter PVC pipe with arcyclic plastic in 360 degrees around. <br><br>I wonder if you guys tested the StereoPI outside for a longer time period (days) on the sun and experienced something like this:<br><br><a href="https://www.raspberrypi.org/forums/viewtopic.php?t=190355" class="postlink">https://www.raspberrypi.org/forums/view ... p?t=190355</a><br><br>That camera works just fine indoors any time I take it in, but outside in sun its just a big whitescreen, not much help from the community either so I will replace it with Stereopi anyway. <br><br>Since this is going to be other part of a project if using dome I was considering having the dome up (face the sky) and having the dome look downwards like regular CCTV cameras. I guess it is not good for it if sun shines directly on it in 35C summer anyway. <br><br>Please let me know all your outdoor experiences with the camera.<br><br>Thank you.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=91">tracer55</a> — Mon May 13, 2019 10:22 am</p><hr />
