	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/19" />
	<updated>2022-01-04T21:57:58+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/19</id>
		<published>2022-01-04T21:57:58+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3022#p3022</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3022#p3022"/>
		<title type="html"><![CDATA[Re: Video Streams Not Working]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3022#p3022"><![CDATA[
Hi Blinky,<br><br>In the latest release of SLP2 (0.12.4) we've updated the video decoding part in the administration panel, and now it works with most of the browsers by default.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Tue Jan 04, 2022 9:57 pm</p><hr />
		<author><name><![CDATA[Blinky]]></name></author>
		<updated>2022-01-04T19:43:52+00:00</updated>
		<published>2022-01-04T19:43:52+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3016#p3016</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3016#p3016"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3016#p3016"><![CDATA[
Found out the standard browser in the Samsung S10e android phone cannot see the browser stream.  Using the Chrome browser on the same phone solved the problem.<br><br>Happy New Year<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=75">Blinky</a> — Tue Jan 04, 2022 7:43 pm</p><hr />
		<updated>2019-05-05T09:04:15+00:00</updated>
		<published>2019-05-05T09:04:15+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=57#p57</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=57#p57"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=57#p57"><![CDATA[
<blockquote class="uncited"><div>I tried the HDMI port and found the same stereo pi logo. <br><br>I found that the camera side of the cables were in backwards. Whooops!!<br><br>After correcting the cables, the unit started rebooting on startup. I found that my laptop didn’t supply enough power to sustain the stereopi. So I tried it with an apple usb charger and it’s working great!</div></blockquote>Wildag, sometimes I repeat this mistake too <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":-)" title="Smile"> I'm glad you've localized and solve this little problem.<br><br>Blinky, thank you for your help!<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Sun May 05, 2019 9:04 am</p><hr />
		<author><name><![CDATA[wildag]]></name></author>
		<updated>2019-05-05T00:26:46+00:00</updated>
		<published>2019-05-05T00:26:46+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=53#p53</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=53#p53"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=53#p53"><![CDATA[
I tried the HDMI port and found the same stereo pi logo. <br><br>I found that the camera side of the cables were in backwards. Whooops!!<br><br>After correcting the cables, the unit started rebooting on startup. I found that my laptop didn’t supply enough power to sustain the stereopi. So I tried it with an apple usb charger and it’s working great!<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=78">wildag</a> — Sun May 05, 2019 12:26 am</p><hr />
		<updated>2019-05-04T22:41:16+00:00</updated>
		<published>2019-05-04T22:41:16+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=52#p52</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=52#p52"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=52#p52"><![CDATA[
Check that the camera cables are in correctly.  Also try to hook a monitor up with the hdmi and you should see at least one camera until you set 3d in the admin area.<br><br>Hope that helps.<br>Regards,<br>Blinky<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=75">Blinky</a> — Sat May 04, 2019 10:41 pm</p><hr />
		<updated>2019-05-04T21:57:12+00:00</updated>
		<published>2019-05-04T21:57:12+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=51#p51</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=51#p51"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=51#p51"><![CDATA[
continued.... When I enable RTSP link, I can telnet to port 554. TCP session is opened, so network connectivity looks good.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=78">wildag</a> — Sat May 04, 2019 9:57 pm</p><hr />
		<updated>2019-05-04T21:50:35+00:00</updated>
		<published>2019-05-04T21:50:35+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=50#p50</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=50#p50"/>
		<title type="html"><![CDATA[Video Streams Not Working]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=50#p50"><![CDATA[
I just received the stereopi deluxe kit. Installed the two wide angle cameras. Connected the USB -&gt; power cord. Inserted a EDiMax Wifi dongle. Added the WLAN0 configuration to stereopi.conf on the provided SD card. Inserted that card into the stereopi. Found the stereopi on my wifi network. <br><br>I can see the stereo pi web console. I can save settings. When I refresh the settings stick.<br><br>When I enable RTSP Link I get not response from an RTSP viewer. <br><br>When I enable browser stream, I see no video in the web console (it appears that maybe I should see it). <br><br>When I enable UDP streaming and use streamer on my mac, I get no video. <br><br>I can use the stereopi web UI to access the console. The only obvious error is in dmsg<br><br>"Unknown hub control request type or invalid typeReq: c033h"<br><br>Any ideas?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=78">wildag</a> — Sat May 04, 2019 9:50 pm</p><hr />
