	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1443" />
	<updated>2025-08-13T20:30:46+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1443</id>
		<published>2025-08-13T20:30:46+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3541#p3541</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3541#p3541"/>
		<title type="html"><![CDATA[Re: Raspberry pi cameras]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3541#p3541"><![CDATA[
Hi,<br><br>The best way is to follow the step-by-step tuning process from our guide. It helps to localize the issue. If you have a good result after each step, you should have a good final result.<br>If you want to go brutally by changing the low-level parameters, it's better to go through the OpenCV's guides, but you have to have a good math and coding experience. for this.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Wed Aug 13, 2025 8:30 pm</p><hr />
		<author><name><![CDATA[panda221]]></name></author>
		<updated>2025-08-12T13:59:44+00:00</updated>
		<published>2025-08-12T13:59:44+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3538#p3538</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3538#p3538"/>
		<title type="html"><![CDATA[Raspberry pi cameras]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3538#p3538"><![CDATA[
I am using rpi cameras module 3 wide. and i am having trouble generating the right depth map. i tried changing sgbm parameters but still it doesnt help. can someone help me in this?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1408">panda221</a> — Tue Aug 12, 2025 1:59 pm</p><hr />
