	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1442" />
	<updated>2026-02-11T18:51:26+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1442</id>
		<published>2026-02-11T18:51:26+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3560#p3560</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3560#p3560"/>
		<title type="html"><![CDATA[Re: Supported cameras]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3560#p3560"><![CDATA[
<blockquote class="uncited"><div>Thanks for the info!<br>No worries, the IMX219 is fine.<br>One more follow-up question: You mentioned <a href="https://forum.stereopi.com/viewtopic.php?p=1893#p1893" class="postlink">here</a> that the cameras should be calibrated using the newer fisheye calibration. Why fisheye calibration? The IMX219 are wide-angle cameras and not fisheye.</div></blockquote>well, the IMX219 is actually the optical sensor. And we have a bunch of camera modules built on it with a lot of different optics (normal, wide, extra wide/fisheye). <br>There are two reasons for using the fishey code:<br>- it's fresher <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":-)" title="Smile"><br>- it handles both "normal" and "fisheye" cameras equally well, so it's universal<br><br>That's fun, but even on "normal" cameras from RPi (declared as non-distortial), fisheye code finds and fixes small barrel distortion <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":-)" title="Smile"><p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Wed Feb 11, 2026 6:51 pm</p><hr />
		<author><name><![CDATA[NMO]]></name></author>
		<updated>2026-02-02T22:45:51+00:00</updated>
		<published>2026-02-02T22:45:51+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3559#p3559</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3559#p3559"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3559#p3559"><![CDATA[
Thanks for the info!<br>No worries, the IMX219 is fine.<br>One more follow-up question: You mentioned <a href="https://forum.stereopi.com/viewtopic.php?p=1893#p1893" class="postlink">here</a> that the cameras should be calibrated using the newer fisheye calibration. Why fisheye calibration? The IMX219 are wide-angle cameras and not fisheye.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1401">NMO</a> — Mon Feb 02, 2026 10:45 pm</p><hr />
		<updated>2025-08-13T20:26:59+00:00</updated>
		<published>2025-08-13T20:26:59+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3540#p3540</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3540#p3540"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3540#p3540"><![CDATA[
Hi NMO,<br><br>This is a tricky border between the world of ready-to-use DIY cameras and advanced camera modules designed for electronics developers.<br><br>In our experience, the most friendly modules can be found at <a href="https://www.arducam.com/embedded-camera-module/cameras-for-raspberrypi.html" class="postlink">Arducam</a> and <a href="https://www.waveshare.com/product/raspberry-pi/cameras.htm" class="postlink">Waveshare</a>.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Wed Aug 13, 2025 8:26 pm</p><hr />
		<updated>2025-08-08T20:11:04+00:00</updated>
		<published>2025-08-08T20:11:04+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3537#p3537</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3537#p3537"/>
		<title type="html"><![CDATA[Supported cameras]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3537#p3537"><![CDATA[
Hi, can you give me some hints where I can find alternative cameras? I have the IMX219 which is included but I would need a camera which has global shutter and can be used with a zoom lense.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1401">NMO</a> — Fri Aug 08, 2025 8:11 pm</p><hr />
