	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1439" />
	<updated>2025-06-16T17:04:41+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1439</id>
		<published>2025-06-16T17:04:41+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3531#p3531</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3531#p3531"/>
		<title type="html"><![CDATA[Re: Images swapped]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3531#p3531"><![CDATA[
Hi NMO,<br><br>Due to the difference on the ribbon cable connector position on the camera, you have to "swap" cameras in settings according to your model. <br><br>To do this in OpenCV you should set "letf" and "right" arrays appropriately. In script 3 you can see <a href="https://github.com/realizator/stereopi-fisheye-robot/blob/114776178d1e62ad8809c0260d3360b536ca2b94/3_pairs_cut.py#L64-L65" class="postlink">these lines here</a>.<br><br>In SLP you can just set a checkbox "swap cameras" in settings.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon Jun 16, 2025 5:04 pm</p><hr />
		<author><name><![CDATA[NMO]]></name></author>
		<updated>2025-06-14T12:19:00+00:00</updated>
		<published>2025-06-14T12:19:00+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3530#p3530</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3530#p3530"/>
		<title type="html"><![CDATA[Images swapped]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3530#p3530"><![CDATA[
I just have assembled my StereoPi cam. I tried the 1_test.py and noticed that the images are swapped. The picture from the left cam is shown on the right side and vice versa. Is that normal?<br><br>EDIT: I noticed that this happens on SLP2 as well.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1401">NMO</a> — Sat Jun 14, 2025 12:19 pm</p><hr />
