	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1437" />
	<updated>2025-05-29T01:04:09+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1437</id>
		<author><name><![CDATA[taa11]]></name></author>
		<published>2025-05-29T01:04:09+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3527#p3527</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3527#p3527"/>
		<title type="html"><![CDATA[Re: Display Rotation for StereoPi v2]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3527#p3527"><![CDATA[
Removing the spaces works, thank you for helping me solve this.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1299">taa11</a> — Thu May 29, 2025 1:04 am</p><hr />
		<updated>2025-05-15T13:43:45+00:00</updated>
		<published>2025-05-15T13:43:45+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3526#p3526</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3526#p3526"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3526#p3526"><![CDATA[
Please try one minor fix.<br>Officially RPF recommends to write lines in config.txt without spaces, like:<div class="codebox"><p>Code: </p><pre><code>display_hdmi_rotate=1</code></pre></div>But in your file you have spaces near the equal mark. Try to remove them.<br>Also, I guess the line for LCD rotation is not needed at all - try to comment it out.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Thu May 15, 2025 1:43 pm</p><hr />
		<updated>2025-05-15T03:27:09+00:00</updated>
		<published>2025-05-15T03:27:09+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3525#p3525</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3525#p3525"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3525#p3525"><![CDATA[
Yes, I did try that as well, but it did not work. I also tried editing cmdline.text but that did not work either.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1299">taa11</a> — Thu May 15, 2025 3:27 am</p><hr />
		<updated>2025-05-13T18:16:37+00:00</updated>
		<published>2025-05-13T18:16:37+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3524#p3524</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3524#p3524"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3524#p3524"><![CDATA[
Yes, I see your vc4-fkms-v3d is correctly commented out.<br>Did you try display_rotate=3 and display_hdmi_rotate=3?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Tue May 13, 2025 6:16 pm</p><hr />
		<updated>2025-05-02T17:17:42+00:00</updated>
		<published>2025-05-02T17:17:42+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3523#p3523</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3523#p3523"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3523#p3523"><![CDATA[
Hi, <br>Thanks for your response. I did try commenting out the fkms statements, but it did not seem to work. Here is the config.txt file: <br>---<br># For more options and information see<br># <a href="http://rpf.io/configtxt" class="postlink">http://rpf.io/configtxt</a><br># Some settings may impact device functionality. See link above for details<br><br>disable_splash=1<br><br># uncomment if you get no picture on HDMI for a default "safe" mode<br>#hdmi_safe=1<br><br># uncomment this if your display has a black border of unused pixels visible<br># and your display can output without overscan<br>disable_overscan=1<br><br># uncomment the following to adjust overscan. Use positive numbers if console<br># goes off screen, and negative if there is too much border<br>#overscan_left=0<br>#overscan_right=0<br>#overscan_top=0<br>#overscan_bottom=0<br><br># uncomment to force a console size. By default it will be display's size minus<br># overscan.<br>framebuffer_width=1080<br>#framebuffer_height=1920<br><br># uncomment if hdmi display is not detected and composite is being output<br>#hdmi_ignore_hotplug=<br>hdmi_force_hotplug=1<br><br># uncomment to force a specific HDMI mode (this will force VGA)<br>hdmi_group=1<br>hdmi_mode=16<br><br># uncomment to force a HDMI mode rather than DVI. This can make audio work in<br># DMT (computer monitor) modes<br>#hdmi_drive=2<br><br># uncomment to increase signal to HDMI, if you have interference, blanking, or<br># no display<br>#config_hdmi_boost=4<br><br># uncomment for composite PAL<br>#sdtv_mode=2<br>#sdtv_aspect=1<br><br>#uncomment to overclock the arm. 700 MHz is the default.<br>#arm_freq=800<br><br># Uncomment some or all of these to enable the optional hardware interfaces<br>dtparam=i2c_arm=on<br>#dtparam=i2s=on<br>dtparam=spi=on<br><br># Uncomment this to enable infrared communication.<br>#dtoverlay=gpio-ir,gpio_pin=17<br>#dtoverlay=gpio-ir-tx,gpio_pin=18<br><br># Additional overlays and parameters are documented /boot/overlays/README<br><br># Enable audio (loads snd_bcm2835)<br>dtparam=audio=on<br><br>avoid_warnings=1<br><br>[pi4]<br># Enable DRM VC4 V3D driver on top of the dispmanx display stack<br>#dtoverlay=vc4-fkms-v3d<br>max_framebuffers=2<br>enable_tvout=0<br><br>[all]<br>#dtoverlay=vc4-fkms-v3d<br>start_x=1<br>gpu_mem=160<br>enable_uart=1<br>dtoverlay=miniuart-bt<br>dtoverlay=dwc2,dr_mode=host<br><br>#waveshare<br>max_framebuffer_height=1920<br>#3-D display<br>#max_framebuffer_height=2880<br>max_usb_current=1<br>config_hdmi_boost=10<br>hdmi_group=2<br>hdmi_force_hotplug=1<br>hdmi_mode=87<br>#waveshare 5.5<br>hdmi_timings=1080 1 26 4 50 1920 1 8 2 6 0 0 0 60 0 135580000 3 <br>#stereo display<br>#hdmi_timings=2880 0 50 8 15 1440 0 8 2 6 0 0 0 60 0 256921800 3 <br><br>display_rotate = 1<br>display_lcd_rotate = 1<br>display_hdmi_rotate = 1<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1299">taa11</a> — Fri May 02, 2025 5:17 pm</p><hr />
		<updated>2025-04-30T13:24:12+00:00</updated>
		<published>2025-04-30T13:24:12+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3522#p3522</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3522#p3522"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3522#p3522"><![CDATA[
Hey taa11,<br><br>Well, commenting fkms in config.txt should do the trick. Could you please share your config.txt?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Wed Apr 30, 2025 1:24 pm</p><hr />
		<updated>2025-04-23T22:37:46+00:00</updated>
		<published>2025-04-23T22:37:46+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3520#p3520</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3520#p3520"/>
		<title type="html"><![CDATA[Display Rotation for StereoPi v2]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3520#p3520"><![CDATA[
Hi, <br>I am using the StereoPi v2 kit with CM4 and SLP2, and the 5.5" Waveshare display used in this guide: <a href="https://stereopi.com/blog/diy-vr-headset-stereopi-10-ms-latency-just-135" class="postlink">https://stereopi.com/blog/diy-vr-headse ... y-just-135</a><br><br>The display_rotate parameter does not work, even after disabling fkms. Also, editing cmdline.txt to rotate the display does not work either. <br><br>Do you have any suggestions to rotate the display 90 degrees? Or at least use the entire display instead of just the middle section. <br>Thank you.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1299">taa11</a> — Wed Apr 23, 2025 10:37 pm</p><hr />
