	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1420" />
	<updated>2024-10-04T19:45:00+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1420</id>
		<published>2024-10-04T19:45:00+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3464#p3464</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3464#p3464"/>
		<title type="html"><![CDATA[Re: CM4 not powered]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3464#p3464"><![CDATA[
It looks like CM4 issue.<br><br>Could you please try to re-seat CM4 and let me know the result?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Fri Oct 04, 2024 7:45 pm</p><hr />
		<author><name><![CDATA[benklee]]></name></author>
		<updated>2024-07-02T09:54:57+00:00</updated>
		<published>2024-07-02T09:54:57+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3454#p3454</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3454#p3454"/>
		<title type="html"><![CDATA[CM4 not powered]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3454#p3454"><![CDATA[
I have recently taken over an active project that uses a stereopi. I could properly boot to an Ubuntu 22.04 SD card without any problems.<br>After working with it a little bit, it now does not boot anymore and only the J-PWR and 5V LEDs are on. Neither the PI-ACT or PWR LEDs turn on.<br>This leads me to believe that there is a hardware malfunction of the stereopi, however i barley touched any of the hardware and mostly worked on the software.<br><br>Has anyone had a similar issue? I could not find any info on what to do if the PWR LED does not even turn on.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1278">benklee</a> — Tue Jul 02, 2024 9:54 am</p><hr />
