	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1379" />
	<updated>2023-07-26T13:33:12+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1379</id>
		<author><name><![CDATA[glowingskull]]></name></author>
		<published>2023-07-26T13:33:12+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3399#p3399</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3399#p3399"/>
		<title type="html"><![CDATA[PiSugar Support on StereoPi 2?]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3399#p3399"><![CDATA[
Has anyone attempted to use a PiSugar power supply with the StereoPi 2 board? <a href="https://github.com/PiSugar/PiSugar/wiki#function-comparison" class="postlink">https://github.com/PiSugar/PiSugar/wiki ... comparison</a><br><br>I know that the pogo pin connection method won't work for the StereoPi 2, since the CM4 covers the underside of the GPIO header, but I figure that can be worked around with creative soldering.<br><br>My questions are:<br><ul><li>Can the StereoPi 2 accept power over the GPIO pins that PiSugar uses?</li></ul><ul><li>Does anything special need to be done for the I2C data channel that newer versions of the PiSugar use to talk to the Pi?</li></ul><p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1006">glowingskull</a> — Wed Jul 26, 2023 1:33 pm</p><hr />
