	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1339" />
	<updated>2023-04-12T20:04:12+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1339</id>
		<published>2023-04-12T20:04:12+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3368#p3368</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3368#p3368"/>
		<title type="html"><![CDATA[Re: PCB stackup detail for StereoPi v2]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3368#p3368"><![CDATA[
Hi maes,<br><br>We used NexPCB company (<a href="https://www.nexpcb.com" class="postlink">https://www.nexpcb.com</a>) and they did both PCB and assembly for us.<br><br>Here are the data you've asked about:<br><br>1 – L1_Top<br>2 – L2_Signal<br>3 – L3_VCC<br>4 – L4_GND<br>5 – L5_Signal<br>6 – L6_Bottom<br><br>L1.   L1_Top                ---------------------------------- 0.018 mm<br>                                             0.150mm<br>L2.  L2_Signal            ---------------------------------- 0.018 mm<br>                                         0.510mm<br>L3.   L3_VCC               ---------------------------------- 0.018 mm<br>                                              0.150mm<br>L4.   L4_GND               ---------------------------------- 0.018 mm<br>                                              0.510mm<br>L5.   L5_Signal             ---------------------------------- 0.018 mm<br>                                              0.150mm<br>L6.   L6_Bottom            ---------------------------------- 0.018 mm<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Wed Apr 12, 2023 8:04 pm</p><hr />
		<author><name><![CDATA[maes]]></name></author>
		<updated>2022-12-22T16:42:07+00:00</updated>
		<published>2022-12-22T16:42:07+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3315#p3315</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3315#p3315"/>
		<title type="html"><![CDATA[PCB stackup detail for StereoPi v2]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3315#p3315"><![CDATA[
I'm working on a small adapter using the same HD-RA-DSF12-TR micro-HDMI connector as the StereoPi v2. Basically a 'super low profile' right angle adapter that would bring one of the Pi4's micro-hdmi ports to the same orientation as the usb and network ports.<br><br>Would you be willing to share details of the PCB stackup (# of layers, pcb thickness, etc) you used for the StereoPi v2 and where they're made?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1129">maes</a> — Thu Dec 22, 2022 4:42 pm</p><hr />
