	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1329" />
	<updated>2022-10-17T09:44:04+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1329</id>
		<published>2022-10-17T09:44:04+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3301#p3301</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3301#p3301"/>
		<title type="html"><![CDATA[Re: SD card not detected]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3301#p3301"><![CDATA[
Hi, angelyn.mercado,<br><br>Well, I'm a bit confused by this information. Technically StereoPi can manage this card size (like the regular Raspberry Pi), but I've never checked this by myself. I'll buy a 128Gb card and test how it works.<br><br>You can use one of the included micro SD cards to image them by the img file you need to proceed with your experiments.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon Oct 17, 2022 9:44 am</p><hr />
		<author><name><![CDATA[angelyn.mercado]]></name></author>
		<updated>2022-10-04T05:00:22+00:00</updated>
		<published>2022-10-04T05:00:22+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3288#p3288</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3288#p3288"/>
		<title type="html"><![CDATA[SD card not detected]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3288#p3288"><![CDATA[
Hello! <br><br>I'm trying to flash the "cpp+python Raspbian" img provided on the Wiki on a 128GB SD Card. <br>I used balenaEtcher and was able to write the image on the card without any problems. <br>However, when I try to use it on StereoPi v2, the bootloader indicates that the SD card is not detected. <br><br>I also tried using Raspberry Pi Imager to flash the OS, no go. <br>I also tried flashing the SLP2 img, works but how to expand the root partition?<br><br>I tried the included SD cards, both SLP and Raspi (green and red) cards, they work fine. <br><br>Am I missing something on flashing the ready-made StereoPi images on an SD card with larger capacity?<br><br>Thanks!<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=300">angelyn.mercado</a> — Tue Oct 04, 2022 5:00 am</p><hr />
