	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1324" />
	<updated>2022-09-16T07:40:33+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1324</id>
		<published>2022-09-16T07:40:33+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3257#p3257</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3257#p3257"/>
		<title type="html"><![CDATA[Re: VR Camera Live Stream Super Low Latency Setup]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3257#p3257"><![CDATA[
Hello carletonustudent,<br><br>To do this project you'll need to do two main steps:<br><br>1. Assemble the kit and test the stream to the Oculus Quest 2. We have an application for this helmet and a special SLP2 RaspiOS image, which can stream to Oculus out of the box.<br><br>2. The next step is to create a connection over 5G. Actually we have a hidden (not advertised yet) feature in SLP - it is ZeroTier network support. When you set this up on the SLP2 and on your local device or network, ZeroTier will do a magic and both remote StereoPi and your device will think that they are in the same local network, and "just work".<br><br>If you have other questions - let me know. I'll be glad to help you with this solution.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Fri Sep 16, 2022 7:40 am</p><hr />
		<author><name><![CDATA[carletonustudent]]></name></author>
		<updated>2022-09-14T20:05:51+00:00</updated>
		<published>2022-09-14T20:05:51+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3255#p3255</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3255#p3255"/>
		<title type="html"><![CDATA[VR Camera Live Stream Super Low Latency Setup]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3255#p3255"><![CDATA[
Hello,<br><br>I am developing a system where I want to be able to use this kit below<br><br><a href="https://www.mouser.ca/ProductDetail/StereoPi/STPI2-CAMKIT-01?qs=DRkmTr78QATth7HOE9y%252BZw%3D%3D" class="postlink">https://www.mouser.ca/ProductDetail/Ste ... 2BZw%3D%3D</a> <br><br>in conjunction with a RPi 4 to stream a live video from the two cameras to either an Oculus Quest 2 or preferably a HP Reverb 2. <br><br>If anyone has experience in this field help would be appreciated I will connect both the receiving and sending devices to a 5g hotspot to do the viewing over the 5g network so was wondering what protocol would be best too, i.e udp, rtsp, skybox cast, etc. <br><br>Again I appreciate the help thank you.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1107">carletonustudent</a> — Wed Sep 14, 2022 8:05 pm</p><hr />
