	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1321" />
	<updated>2022-09-08T09:14:55+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1321</id>
		<published>2022-09-08T09:14:55+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3247#p3247</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3247#p3247"/>
		<title type="html"><![CDATA[Re: New CM3 Flash - not detecting one camera]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3247#p3247"><![CDATA[
If you have a perfectly working setup and need to troubleshoot another setup, I recommend to do three steps:<br>1. Take the micro SD from the working setup and back it up by creating IMG file. THis can help you in the future as a "reference" image, which was proven to work.<br>2. Create a copy ot this micro SD card, try to boot it on the first working setup. This is to check that the copy is correct<br>3. Insert this copied card to your new rig. If it has some issues after boot - it means the issue is on the hardware part, since software is checked and approved. If it has no issues - it just works, and you can use it.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Thu Sep 08, 2022 9:14 am</p><hr />
		<author><name><![CDATA[atrunyan]]></name></author>
		<updated>2022-09-07T14:21:55+00:00</updated>
		<published>2022-09-07T14:21:55+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3239#p3239</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3239#p3239"/>
		<title type="html"><![CDATA[New CM3 Flash - not detecting one camera]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3239#p3239"><![CDATA[
I have been using StereoPi v0.9. I have a perfectly working setup, that both cameras are detected. When I went to replicate the same set up with another StereoPi v0.9, and with two different boards, the left ribbon cable port is not detecting a camera. The same cameras are properly detected in my original set up. Is there something else I should do in addition to adding the dt-blob.bin file? I've enabled camera interfaces and even tried turning dtcparam=i2c_arm to off in the config.txt file. Please assist<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1009">atrunyan</a> — Wed Sep 07, 2022 2:21 pm</p><hr />
