	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1318" />
	<updated>2022-09-08T08:06:21+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1318</id>
		<published>2022-09-08T08:06:21+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3241#p3241</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3241#p3241"/>
		<title type="html"><![CDATA[Re: Right Camera Calibration Issues]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3241#p3241"><![CDATA[
Hi atrunyan,<br><br>I've spotted your "cutted" pairs looks swapped, i.e. left image is actually a right image.<br>Examples: <br><a href="https://github.com/atrunyan/stereopi_URIL/blob/6b195941a531f2168af4b24e7286cce7dea1c4ac/pairs_land_calib/left_01.png" class="postlink">https://github.com/atrunyan/stereopi_UR ... eft_01.png</a><br><a href="https://github.com/atrunyan/stereopi_URIL/blob/6b195941a531f2168af4b24e7286cce7dea1c4ac/pairs_land_calib/right_01.png" class="postlink">https://github.com/atrunyan/stereopi_UR ... ght_01.png</a><br><br>Could you please check this part of your pair-cutting code?<br><br>Also I can't realize either you are using a wide-angle camera, or the chess-board is not a plane? ( I guess it's a widfe-angle with specific optics...)<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Thu Sep 08, 2022 8:06 am</p><hr />
		<author><name><![CDATA[atrunyan]]></name></author>
		<updated>2022-08-15T15:11:11+00:00</updated>
		<published>2022-08-15T15:11:11+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3232#p3232</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3232#p3232"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3232#p3232"><![CDATA[
Thank you! I actually caught this same error shortly after posting my issue. It is now fixed!<br><br>I am still not getting a well-defined disparity map though. My maps are all very noisy, there is no clear shapes even for a basic picture of a box against a blank wall.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1009">atrunyan</a> — Mon Aug 15, 2022 3:11 pm</p><hr />
		<updated>2022-08-15T10:11:20+00:00</updated>
		<published>2022-08-15T10:11:20+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3231#p3231</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3231#p3231"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3231#p3231"><![CDATA[
I did not test your code, but by reading it rapidly, I noticed an error here:<br><a href="https://github.com/atrunyan/stereopi_URIL/blob/6b195941a531f2168af4b24e7286cce7dea1c4ac/cv_calibrate_stereo.py#L56" class="postlink">https://github.com/atrunyan/stereopi_UR ... reo.py#L56</a><br>Not read afterwards.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=101">stereomaton</a> — Mon Aug 15, 2022 10:11 am</p><hr />
		<updated>2022-08-12T15:05:40+00:00</updated>
		<published>2022-08-12T15:05:40+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3229#p3229</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3229#p3229"/>
		<title type="html"><![CDATA[Right Camera Calibration Issues]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3229#p3229"><![CDATA[
I'm using the stereopi set up, and created my own script using opencv for calibration. The chessboard corners are detected very well in the left camera images each time, but the right camera images struggle to correctly identify chessboard corners. Below is the link to my github with the code. I have been using the images in the "pairs_land_calib" folder as well as the script, cv_calibrate_stereo.py<br><br><a href="https://github.com/atrunyan/stereopi_URIL.git" class="postlink">https://github.com/atrunyan/stereopi_URIL.git</a><br><img src="https://files.slack.com/files-pri/T014FGD4UCW-F03SRHVFP8X/image.png" class="postimage" alt="Image"><p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1009">atrunyan</a> — Fri Aug 12, 2022 3:05 pm</p><hr />
