	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1315" />
	<updated>2022-07-11T16:29:34+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1315</id>
		<author><name><![CDATA[dnaman]]></name></author>
		<published>2022-07-11T16:29:34+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3225#p3225</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3225#p3225"/>
		<title type="html"><![CDATA[Re: Vertical Misalignment]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3225#p3225"><![CDATA[
Thanks, Eugene. I don't even know what OpenCV is .... afaik I'm using SLP2. I think I have some swatting-up to do.<br><br>I'm "playing" again. This time with macro. I've made a new camera mount plate and I'm using the original RPi cameras so that I can adjust their positions and also angle them inwards. But there's no adjustment, of course, on those cameras for sensor position. I can shim the whole camera if necessary though.<br><br>(Unfortunately, because of some local "circumstances", I only get time on this stuff at sporadic intervals and have to re-learn it all each time  <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_sad.gif" width="15" height="17" alt=":(" title="Sad">   )<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1002">dnaman</a> — Mon Jul 11, 2022 4:29 pm</p><hr />
		<updated>2022-07-11T08:51:33+00:00</updated>
		<published>2022-07-11T08:51:33+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3224#p3224</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3224#p3224"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3224#p3224"><![CDATA[
Hi dnaman,<br><br>If you are using StereoPi with OpenCV, then you can use calibration procedure. After that you'll get aligned images even if they were vertically misaligned.<br><br>If you are using StereoPi for the stereoscopic photo, you can also use post-processing tools like Stereo Photo Maker. Take a look at the "Processing the photos" section in <a href="https://stereopi.com/blog/art-stereoscopic-photo-part-2" class="postlink">this article</a>.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon Jul 11, 2022 8:51 am</p><hr />
		<updated>2022-07-06T21:05:48+00:00</updated>
		<published>2022-07-06T21:05:48+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3188#p3188</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3188#p3188"/>
		<title type="html"><![CDATA[Vertical Misalignment]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3188#p3188"><![CDATA[
Can anyone confirm that the only way to fix vertical misalignment of the two images is by adjusting the hardware.<br><br>I had thought there was a way to do it in the software but I can't find it.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1002">dnaman</a> — Wed Jul 06, 2022 9:05 pm</p><hr />
