	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1304" />
	<updated>2022-07-01T12:22:11+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1304</id>
		<published>2022-07-01T12:22:11+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3179#p3179</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3179#p3179"/>
		<title type="html"><![CDATA[Re: Splitting stereo video into two videos?]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3179#p3179"><![CDATA[
Hi atrunyan,<br><blockquote class="uncited"><div>I am also looking into how to give it my calibration camera info to get accurately sized models.</div></blockquote> - as I understand, you can use the <a href="https://agisoft.freshdesk.com/support/solutions/articles/31000160059-lens-calibration-using-chessboard-pattern-in-metashape" class="postlink">built-in Agisoft calibration</a>. I.e. just feed it up with calibration images, and it'll calibrate camera.<br><br>I'm not familiar with Agisoft, but brief search shows me a few topics related to the camera specs passing to the code (like <a href="https://www.agisoft.com/forum/index.php?topic=13309.0" class="postlink">this one</a>). So I think you can either calibrate images inside Agisoft, or try to pass your calibnration data. I'd prefer the first way.<br><br>Also, AFAIK, photogrammetry usually rely on the sequence of frames from one camera (preferrably including the camera position/orientation data for each frame). But this is too specific topic, related to Agisoft.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Fri Jul 01, 2022 12:22 pm</p><hr />
		<author><name><![CDATA[atrunyan]]></name></author>
		<updated>2022-06-30T18:21:11+00:00</updated>
		<published>2022-06-30T18:21:11+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3178#p3178</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3178#p3178"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3178#p3178"><![CDATA[
Hi Realizator, <br>I'm trying to create 3D models in agisoft from collected stereovideo, and I'm unsure if I can directly input stereo video into the software, or if I need to input frames from each camera. I am also looking into how to give it my calibration camera info to get accurately sized models.<br>Also, Id like to create depth maps from pre-recorded video, but am unsure how to do that and save the depth map video. I'm able to see depth maps with stills, but still unable to save the result.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1009">atrunyan</a> — Thu Jun 30, 2022 6:21 pm</p><hr />
		<updated>2022-05-13T07:16:54+00:00</updated>
		<published>2022-05-13T07:16:54+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3127#p3127</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3127#p3127"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3127#p3127"><![CDATA[
Stereomaton, thank you for your answer! <br><br>atrunyan, I'm curious why do you need two independent video files to get the disparity map, but not the single side-by-side file. What's the aim of the project?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Fri May 13, 2022 7:16 am</p><hr />
		<updated>2022-05-13T04:56:56+00:00</updated>
		<published>2022-05-13T04:56:56+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3126#p3126</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3126#p3126"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3126#p3126"><![CDATA[
For offline conversion (after the half-sbs file is created), here is a <em class="text-italics">ffmpeg</em> command to split your video <em class="text-italics">input.mp4</em> into two files <em class="text-italics">output_l.mp4</em> and <em class="text-italics">output_r.mp4</em>:<div class="codebox"><p>Code: </p><pre><code>ffmpeg -i input.mp4 -filter_complex 'split[a][b],[a]stereo3d=sbs2l:ml[l],[b]stereo3d=sbs2l:mr[r]' -map '[l]' output_l.mp4 -map '[r]' output_r.mp4</code></pre></div>If you want to do it live, see <a href="https://github.com/realizator/stereopi-fisheye-robot" class="postlink">https://github.com/realizator/stereopi-fisheye-robot</a> (and in particular <em class="text-italics">6_dm_video.py</em> for live disparity map after the calibration is done ; you can also find a code to split the frame in two images in this file if you are interested in this specific part only)<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=101">stereomaton</a> — Fri May 13, 2022 4:56 am</p><hr />
		<updated>2022-05-12T20:58:07+00:00</updated>
		<published>2022-05-12T20:58:07+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3125#p3125</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3125#p3125"/>
		<title type="html"><![CDATA[Splitting stereo video into two videos?]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3125#p3125"><![CDATA[
Hi, I'm hoping to be able to split my recorded split screen video into a left and right video so that I can make a disparity map video from them. Is this possible? How would I go about doing this?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1009">atrunyan</a> — Thu May 12, 2022 8:58 pm</p><hr />
