	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1291" />
	<updated>2022-03-18T19:53:09+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1291</id>
		<author><name><![CDATA[glowingskull]]></name></author>
		<published>2022-03-18T19:53:09+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3080#p3080</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3080#p3080"/>
		<title type="html"><![CDATA[Re: Vertical Shift between left and right image]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3080#p3080"><![CDATA[
I have a minor vertical shift between the left and right images. It sounds like we both have a physical misalignment of the cameras relative to each other. I would suggest resettling them on the backplate.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1006">glowingskull</a> — Fri Mar 18, 2022 7:53 pm</p><hr />
		<author><name><![CDATA[stoffel61]]></name></author>
		<updated>2022-03-12T17:12:12+00:00</updated>
		<published>2022-03-12T17:12:12+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3079#p3079</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3079#p3079"/>
		<title type="html"><![CDATA[Vertical Shift between left and right image]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3079#p3079"><![CDATA[
Hi,<br><br>I bought the StereoPi v2 no CM4 Camera Kit, because I didn't want to have any problem with<br>the alignment of the cameras. I put everything together and started SLP. That works fine so far,<br>but I have quite a strong vertical shift between the left and right image. What is the problem<br>here? <br><br>Regards,<br>Chris<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1028">stoffel61</a> — Sat Mar 12, 2022 5:12 pm</p><hr />
