	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1258" />
	<updated>2021-11-22T18:07:02+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1258</id>
		<published>2021-11-22T18:07:02+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2961#p2961</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2961#p2961"/>
		<title type="html"><![CDATA[Re: BEWARE! New Raspberry PI OS version Bullseye may break existing projects]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2961#p2961"><![CDATA[
Yes, I'll update the Wiki soon.<br>As for the libcamera - at least we know it supports hardware h264 encoding <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":)" title="Smile"> But MJPEG is not supported yet. While we are waiting for the official stereoscopic support in Bullseye, we try to test all other options we have now.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon Nov 22, 2021 6:07 pm</p><hr />
		<author><name><![CDATA[reds71]]></name></author>
		<updated>2021-11-22T17:46:09+00:00</updated>
		<published>2021-11-22T17:46:09+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2958#p2958</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2958#p2958"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2958#p2958"><![CDATA[
Thanks you for the feedback! Will you post a Warning in the Wiki?<br><br>Regarding the new V4L driver, I hope it will be at the PiCamera functional level (if not the at same performance...). Because before getting a StereoPi, I tried with an USB camera, using the same sensor than the official RPi Camera v2, and I never could get a usable image in OpenCV...<br><br>Cheers<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1022">reds71</a> — Mon Nov 22, 2021 5:46 pm</p><hr />
		<updated>2021-11-22T17:17:59+00:00</updated>
		<published>2021-11-22T17:17:59+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2956#p2956</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2956#p2956"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2956#p2956"><![CDATA[
Hello Stéphane,<br>Thank you for your notice!<br>Actually, I have a talk with Gordon Hollingworth from RPF a month ago, and here are some news:<br>1. RaspiOS Buster now is considered as a candidate to LTS version. LTS means Long Time Support, and expected support range is up to 2026. Since Buster has all functionality we need (GPU core support, MMAL and raspivid/raspistill), we can stay with this version for some time<br>2. It is tricky, but possible to compile old stack (raspivid/raspistill) for Bullseye. We did this, it works, but this is not the way to go.<br>3. Bullseye with the new libcamera apps will support stereoscopic mode, but not from the very beginning. Right now we are looking at some specific usecases (like stereoscopic photo/video and computer vision) and try to experiment with available options to work "out of the box".<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon Nov 22, 2021 5:17 pm</p><hr />
		<updated>2021-11-22T10:45:56+00:00</updated>
		<published>2021-11-22T10:45:56+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2955#p2955</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2955#p2955"/>
		<title type="html"><![CDATA[BEWARE! New Raspberry PI OS version Bullseye may break existing projects]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2955#p2955"><![CDATA[
Hi!<br>Very new here... And I did not know how to spread the info.<br><br>It seems that <strong class="text-strong">the brand new version of Rasperry OS named "Bullseye" breaks compatibility with the old Broadcom drivers</strong> with potential great impact for the Steropi community, as described <a href="https://www.raspberrypi.com/news/bullseye-camera-system/" class="postlink">here</a>. It may result:<ul><li><strong class="text-strong"> No support for stereo capture yet</strong>,</li></ul><ul><li>PiCamera python module disappearance (as well as utils like raspistill),</li></ul><ul><li>No use of the GPU for image pre-processing pipeline, which may result on performance loss.</li></ul><br>Think a warning should be added to the Wiki (maybe I could do it now with my account?)<br><br>Cheers<br><br>Stéphane<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1022">reds71</a> — Mon Nov 22, 2021 10:45 am</p><hr />
