	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1251" />
	<updated>2022-06-08T19:07:32+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1251</id>
		<author><name><![CDATA[asdf]]></name></author>
		<published>2022-06-08T19:07:32+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3167#p3167</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3167#p3167"/>
		<title type="html"><![CDATA[Re: Stereopi v2 as usb device]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3167#p3167"><![CDATA[
Found it! As it turns out, I had to connect the usb_cli jumper in the stereopi, which I learned is necessary from <a href="https://www.stereopi.com/blog/how-we-developed-stereopi-v2-overcoming-6-failures-along-way" class="postlink"> this article</a>.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1080">asdf</a> — Wed Jun 08, 2022 7:07 pm</p><hr />
		<updated>2022-06-08T10:52:24+00:00</updated>
		<published>2022-06-08T10:52:24+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3166#p3166</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3166#p3166"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3166#p3166"><![CDATA[
The article was written for v0.9, I do not have a v2 and thus I did not examine the differences.<br><br>You may look at <em class="text-italics">dmesg</em> command to see if the kennel emits an error message about it.<br><br>By the way, I see in your config.txt that you set both dr_mode=host and peripheral which could likely be a problem.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=101">stereomaton</a> — Wed Jun 08, 2022 10:52 am</p><hr />
		<updated>2022-06-07T18:40:00+00:00</updated>
		<published>2022-06-07T18:40:00+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3165#p3165</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3165#p3165"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3165#p3165"><![CDATA[
I did as described in <a href="https://stereopi.com/blog/stereopi-used-usb-device" class="postlink">the article</a> and I cannot make it work, at least with the Stereopi v2. The device does not show up on my host computer. I have tried powering it from one of the usb-a ports in my computer and also from the usb-c one. Is there a problem with the v2?<br><br>My /boot/config.txt file is:<br><div class="codebox"><p>Code: </p><pre><code># For more options and information see# http://rpf.io/configtxt# Some settings may impact device functionality. See link above for details# uncomment if you get no picture on HDMI for a default "safe" mode#hdmi_safe=1# uncomment this if your display has a black border of unused pixels visible# and your display can output without overscan#disable_overscan=1# uncomment the following to adjust overscan. Use positive numbers if console# goes off screen, and negative if there is too much border#overscan_left=16#overscan_right=16#overscan_top=16#overscan_bottom=16# uncomment to force a console size. By default it will be display's size minus# overscan.#framebuffer_width=1280#framebuffer_height=720# uncomment if hdmi display is not detected and composite is being output#hdmi_force_hotplug=1# uncomment to force a specific HDMI mode (this will force VGA)#hdmi_group=1#hdmi_mode=1# uncomment to force a HDMI mode rather than DVI. This can make audio work in# DMT (computer monitor) modes#hdmi_drive=2# uncomment to increase signal to HDMI, if you have interference, blanking, or# no display#config_hdmi_boost=4# uncomment for composite PAL#sdtv_mode=2#uncomment to overclock the arm. 700 MHz is the default.#arm_freq=800# Uncomment some or all of these to enable the optional hardware interfaces#dtparam=i2c_arm=on#dtparam=i2s=on#dtparam=spi=on# Uncomment this to enable infrared communication.#dtoverlay=gpio-ir,gpio_pin=17#dtoverlay=gpio-ir-tx,gpio_pin=18# Additional overlays and parameters are documented /boot/overlays/README# Enable audio (loads snd_bcm2835)dtparam=audio=on[pi4]# Enable DRM VC4 V3D driver on top of the dispmanx display stackdtoverlay=vc4-fkms-v3dmax_framebuffers=2[all]#dtoverlay=vc4-fkms-v3ddtoverlay=dwc2,dr_mode=hoststart_x=1gpu_mem=512dtoverlay=dwc2,dr_mode=peripheral</code></pre></div>and my /boot/cmdline.txt is <br><div class="codebox"><p>Code: </p><pre><code>console=serial0,115200 console=tty1 root=PARTUUID=cecda96b-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles modules-load=dwc2,g_ether</code></pre></div><p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1080">asdf</a> — Tue Jun 07, 2022 6:40 pm</p><hr />
		<author><name><![CDATA[anu1905]]></name></author>
		<updated>2021-11-13T14:49:20+00:00</updated>
		<published>2021-11-13T14:49:20+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2942#p2942</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2942#p2942"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2942#p2942"><![CDATA[
The HDMI--USB video capture device worked like a charm! Thank you so much!<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1017">anu1905</a> — Sat Nov 13, 2021 2:49 pm</p><hr />
		<updated>2021-11-08T10:35:22+00:00</updated>
		<published>2021-11-08T10:35:22+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2936#p2936</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2936#p2936"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2936#p2936"><![CDATA[
Hello anu1905,<br>To say briefly you have two ways:<br>1. The simplest one - use HDMI-&gt;USB adaptor<br>In this case, the HDMI capture device (like <a href="https://www.amazon.com/dp/B08N66XVD8?psc=1&amp;ref=ppx_yo2_dt_b_product_details9" class="postlink">this one</a>) captures the StereoPi HDMI output. So this device is visible as a web camera. No settings, no tricks.<br>2. The most difficult - use USB gadget mode<br>You can force StereoP to use a USB C port in client mode. And StereoPi can act as a USB device - for example, Ethernet card, storage, etc. For example, in <a href="https://stereopi.com/blog/stereopi-used-usb-device" class="postlink">this article</a>, you can find a way to use a USB connection as a network (it's for V1, but applicable to V2 too).<br>But webcam mode is a challenging feature. All known software realizations are unstable and tricky. The most stable realization is <a href="https://www.jeffgeerling.com/blog/2020/raspberry-pi-makes-great-usb-webcam-100" class="postlink">described here</a> by Jeff Geerling, but it is for the single camera only. <br><br>I know StereoPi v2 is used in USB mode in some advanced projects. But in those cases, it uses a USB connection as a network to pass through the video stream to the host PC, with appropriate receiving part at the Big Brother.<br><br>So, if you want to use it in "just works" mode - use the HDMI-USB capture device.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon Nov 08, 2021 10:35 am</p><hr />
		<updated>2021-11-07T14:21:59+00:00</updated>
		<published>2021-11-07T14:21:59+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2930#p2930</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2930#p2930"/>
		<title type="html"><![CDATA[Stereopi v2 as usb device]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2930#p2930"><![CDATA[
Hello, I would like to use my Stereopi v2 (with CM4) as a USB device. I'm a macOS user and I need the stereopi to be recognized on my MacBook as a webcam. Could someone guide and/or provide instructions? Thanks!<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1017">anu1905</a> — Sun Nov 07, 2021 2:21 pm</p><hr />
