	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1250" />
	<updated>2021-11-08T17:26:26+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1250</id>
		<author><name><![CDATA[dnaman]]></name></author>
		<published>2021-11-08T17:26:26+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2939#p2939</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2939#p2939"/>
		<title type="html"><![CDATA[Re: SP2 HQ Housing Assembly IR Filter Assembly]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2939#p2939"><![CDATA[
Thanks, Realizator, I think if you just mention the (US) glue that you used, people could make their own local match.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1002">dnaman</a> — Mon Nov 08, 2021 5:26 pm</p><hr />
		<updated>2021-11-08T08:23:17+00:00</updated>
		<published>2021-11-08T08:23:17+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2933#p2933</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2933#p2933"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2933#p2933"><![CDATA[
Dnaman, I’ve answered you by email. As for the glue - looks like I need to collect a few “local” names of glues applicable, since the glue name might differ from country to country.<br>Amphi, please write me an email to [mynickname]@gmail.com and I’ll send you the IR filter replacement.<br>Yup, this plastic bag packing do adds unexpected issues for the IR filters.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon Nov 08, 2021 8:23 am</p><hr />
		<author><name><![CDATA[amphi]]></name></author>
		<updated>2021-11-07T10:34:51+00:00</updated>
		<published>2021-11-07T10:34:51+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2928#p2928</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2928#p2928"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2928#p2928"><![CDATA[
my filters look the same and are completely unusable. My guess is because of the plastic bags. where can i get replacement filters?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=993">amphi</a> — Sun Nov 07, 2021 10:34 am</p><hr />
		<updated>2021-11-06T19:06:41+00:00</updated>
		<published>2021-11-06T19:06:41+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2925#p2925</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2925#p2925"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2925#p2925"><![CDATA[
In the absence of any help, I went ahead and used some LePage "Ultra Gel" Super Glue which seems to have worked quite well.<br><br>The built-in applicator with this allows you  to accurately place a small drop without the use of a toothpick and it worked quite well for me. It may help to use a pair of rounded-tip tweezers (with tape over the tips) to place the filter in position, if you have clumsy fingers.<br><br>LePage is, I believe, from the Henkel Pattex stable and may be known by that brand name elsewhere.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1002">dnaman</a> — Sat Nov 06, 2021 7:06 pm</p><hr />
		<updated>2021-11-03T21:07:39+00:00</updated>
		<published>2021-11-03T21:07:39+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2923#p2923</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2923#p2923"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2923#p2923"><![CDATA[
Any response?<br><br>I'm referring to the glue needed to install the IR filters in the black carriages.<br><br>The assembly notes say:<br><br>"Note: please do not use the cyanoacrylate "one-second" glue! Its condensed vapors<br>can leave traces on the filter. Also, it is too liquid and can stain the filter. The best glue<br>to use is transparent thick one like Henkel Pattex."<br><br>I don't understand whether it's saying not to use cyanoacrylate at all (in which case what alternative to use?) or just not to use the "one-second" type.<br><br>I've go everything ready to assemble apart from this.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1002">dnaman</a> — Wed Nov 03, 2021 9:07 pm</p><hr />
		<updated>2021-11-02T16:07:14+00:00</updated>
		<published>2021-11-02T16:07:14+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2920#p2920</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2920#p2920"/>
		<title type="html"><![CDATA[SP2 HQ Housing Assembly IR Filter Assembly]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2920#p2920"><![CDATA[
Can you be more specific for the type of glue recommended?<br><br>"Henkel Pattex" covers a wide range of product from that manufacturer and if you're not familiar with them ....<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1002">dnaman</a> — Tue Nov 02, 2021 4:07 pm</p><hr />
