	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1243" />
	<updated>2024-10-04T19:43:10+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1243</id>
		<published>2024-10-04T19:43:10+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3463#p3463</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3463#p3463"/>
		<title type="html"><![CDATA[Re: Cameras supported=0 detected=0]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3463#p3463"><![CDATA[
Hello Ismud,<br><br>Bookworm has a new video subsystem (libcamera) without stereoscopic support. We'll try to use libcamera, but it's challenging.<br><br>You can use Buster, which has MMAL/raspivid/raspistill video stack. You can also download the ready-to-use Buster with the latest kernel and OpenCV installed: <a href="https://app.mediafire.com/nzr90vj8wp1l3" class="postlink">https://app.mediafire.com/nzr90vj8wp1l3</a><p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Fri Oct 04, 2024 7:43 pm</p><hr />
		<author><name><![CDATA[ismud]]></name></author>
		<updated>2024-07-09T09:32:32+00:00</updated>
		<published>2024-07-09T09:32:32+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3455#p3455</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3455#p3455"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3455#p3455"><![CDATA[
Hi Realizator,<br><br>I have the same issue. I have downloaded dt-blob zip file from the url that you provided and unzipped it. I am using bookworm on Stereopi (CM3+), so I have tried putting dt-blob.bin file both in /boot and /boot/firmware but with no luck.<br><br>uname -a: 6.6.31+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.31-1+rpt1 (2024-05-29) aarch64 GNU/Linux<br><br>Can you help me please?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=245">ismud</a> — Tue Jul 09, 2024 9:32 am</p><hr />
		<updated>2021-10-28T13:48:17+00:00</updated>
		<published>2021-10-28T13:48:17+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2900#p2900</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2900#p2900"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2900#p2900"><![CDATA[
Hi atrunyan,<br>" supported=0" means the system was not able to find the dt-blob.bin file<br>Could you please check that:<br>1. You got the <a href="https://wiki.stereopi.com/files/dt-blob.bin.zip" class="postlink">latest dt-blob bin file</a><br>2. You unzipped the file before putting it to the /boot partition<br><br>upd&gt; Which StereoPi version and RaspiOS are you using?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Thu Oct 28, 2021 1:48 pm</p><hr />
		<author><name><![CDATA[atrunyan]]></name></author>
		<updated>2021-10-22T17:03:00+00:00</updated>
		<published>2021-10-22T17:03:00+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2896#p2896</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2896#p2896"/>
		<title type="html"><![CDATA[Cameras supported=0 detected=0]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2896#p2896"><![CDATA[
I am getting supported=0 detected=0 when running  vcgencmd get_camera even though I put the dt-blob.bin file into my boot folder during initial configuration and enabled cameras through raspi-config. What other steps could I take to fix this issue?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1009">atrunyan</a> — Fri Oct 22, 2021 5:03 pm</p><hr />
