	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1214" />
	<updated>2021-09-15T13:35:24+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1214</id>
		<author><name><![CDATA[zoldaten]]></name></author>
		<published>2021-09-15T13:35:24+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2806#p2806</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2806#p2806"/>
		<title type="html"><![CDATA[Re: wi-fi only 2Mb/s ?]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2806#p2806"><![CDATA[
<blockquote class="uncited"><div>Hey Zoldaten,<br>If you are talking about the SLP2 - it shows you the current video bitrate, but not the WiFi speed. You can change the video bitrate in settings.</div></blockquote>i`m still with stereopi V1. Whats the best bitrate for it ? <br>Can`t  remove artifacts on videosteam. Used to think that it was a result of bad wi-fi and/or bad usb dongle. <br>But after that i replaced everything, tried 2.4 and 5Ghz i suppose is not.<br><br><br>p.s.thanks for quick reply )<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=60">zoldaten</a> — Wed Sep 15, 2021 1:35 pm</p><hr />
		<updated>2021-09-14T21:32:05+00:00</updated>
		<published>2021-09-14T21:32:05+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2801#p2801</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2801#p2801"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2801#p2801"><![CDATA[
Hey Zoldaten,<br>If you are talking about the SLP2 - it shows you the current video bitrate, but not the WiFi speed. You can change the video bitrate in settings.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Tue Sep 14, 2021 9:32 pm</p><hr />
		<updated>2021-09-14T19:00:10+00:00</updated>
		<published>2021-09-14T19:00:10+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2800#p2800</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2800#p2800"/>
		<title type="html"><![CDATA[wi-fi only 2Mb/s ?]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2800#p2800"><![CDATA[
hi.<br><br>i go on with my stereopi - <a href="https://habr.com/ru/post/573986/" class="postlink">https://habr.com/ru/post/573986/</a><br>But have a little trouble.<br><br>How to speed up a wifi ?<br>I use usb stick with good speeds which work in 5Ghz and 2,4Ghz. So i use 5Ghz for a moment.<br>More over i use stand alone router tp-link AX3000.<br><br>With <strong class="text-strong">iwconfig</strong> i see that the link possible with 434Mb/s but SLP image shows only 2Mb/s<br>How to change that ? Is it possible ?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=60">zoldaten</a> — Tue Sep 14, 2021 7:00 pm</p><hr />
