	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1151" />
	<updated>2021-09-15T13:51:18+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1151</id>
		<author><name><![CDATA[zoldaten]]></name></author>
		<published>2021-09-15T13:51:18+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2807#p2807</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2807#p2807"/>
		<title type="html"><![CDATA[Re: Photo capture fails.]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2807#p2807"><![CDATA[
<blockquote class="uncited"><div> If I press the GPIO button preconfigured for taking photos, nothing happens.</div></blockquote>As i found out when you set up GPIO button in settings stereopi starts capturing video when it starts.<br>To stop the process GPIO button preconfigured should be pulled to GND. So i put physical button linked it with GPIO5 and GND on a raspberry.<br>Stereopi should start with button pressed (see explanation above). To take a video just unpress the button and to stop press it again.<br>While to videocapturing is on you cannot make a photo so it leads to error.<br>Try to kill raspivid process but it will reborn as GPIO in settings is switch on.<blockquote class="uncited"><div>I cannot find the file /var/www/html/make_photo.php (that existed under SLP 0.2.3), so I cannot check what is trying to be run when I press the photo button on the WebUI. </div></blockquote>make_photo.php replaced with dl.php and javascripts as i investigated.<blockquote class="uncited"><div>Maybe it tries to save to a different folder than /mnt/DCIM ? How can I check this ?</div></blockquote>All photos still go to /mnt/DCIM. Just visit the dir or update if u`re already there.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=60">zoldaten</a> — Wed Sep 15, 2021 1:51 pm</p><hr />
		<author><name><![CDATA[kvic]]></name></author>
		<updated>2021-06-03T22:18:58+00:00</updated>
		<published>2021-06-03T22:18:58+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2702#p2702</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2702#p2702"/>
		<title type="html"><![CDATA[Photo capture fails.]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2702#p2702"><![CDATA[
Dear forum members,<br><br>I have the following issue: I can make videos via pressing the record button on the WebUI or even by pressing the preconfigured GPIO button on a display HAT (strangely this only works while also the WebUI is displayed). However I cannot make photo snapshots. If I click on the WebUI's make photo button, I get a failed text on the bottom left. If I click this text (it's a link actually), a new tab opens in the browser with [IP address of Pi]/dl.php?file=failed and there the only text is: Wrong file. If I press the GPIO button preconfigured for taking photos, nothing happens. I can make photos via SSH by starting e.g. sudo raspistill -o photo-210603.jpg while I'm in /mnt/DCIM. Now I use SLP 2 image, v 0.8.19 and I cannot find the file /var/www/html/make_photo.php (that existed under SLP 0.2.3), so I cannot check what is trying to be run when I press the photo button on the WebUI. Maybe it tries to save to a different folder than /mnt/DCIM ? How can I check this ? On the admin panel MicroSDcard is set, so I believe photos should be stored in this folder. The video files are there at least, but no photos.<br>Could someone please help?<br>Further details: StereoPI 1 board with 2 Pi v2 camera modules, CM 3+ Lite and microSD card, Waveshare 1.3" TFT HAT with 4 buttons<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=802">kvic</a> — Thu Jun 03, 2021 10:18 pm</p><hr />
