	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/113" />
	<updated>2019-07-02T14:04:58+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/113</id>
		<published>2019-07-02T14:04:58+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=391#p391</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=391#p391"/>
		<title type="html"><![CDATA[Re: StereoPi 0.9 2 pins instead of 3]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=391#p391"><![CDATA[
<img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_biggrin.gif" width="15" height="17" alt=":D" title="Very Happy"> Рад помочь!<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Tue Jul 02, 2019 2:04 pm</p><hr />
		<author><name><![CDATA[dionis.moldovan]]></name></author>
		<updated>2019-07-02T09:53:15+00:00</updated>
		<published>2019-07-02T09:53:15+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=390#p390</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=390#p390"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=390#p390"><![CDATA[
Понял, спасибо <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":)" title="Smile"><p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=142">dionis.moldovan</a> — Tue Jul 02, 2019 9:53 am</p><hr />
		<updated>2019-07-02T09:01:15+00:00</updated>
		<published>2019-07-02T09:01:15+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=388#p388</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=388#p388"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=388#p388"><![CDATA[
Hello dionis.moldovan,<br>Originally there were 3 pins (revision 0.7). Connecting 1-2 means firmware update mode, 2-3 is just for keep jumper on the board. <br>In version 0.9 we kept just 2 pins to avoid occasional misconfiguration. So for firmware update mode you need to put jumper on these 2 pins.<br><br>DIY trick: you may use additional short power cable from your kit, and use it as a jumper. White connector has 2.54 mm step, right like jumper pins. Connect power cable wires together, and put white connector on pins.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Tue Jul 02, 2019 9:01 am</p><hr />
		<updated>2019-07-02T08:56:04+00:00</updated>
		<published>2019-07-02T08:56:04+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=387#p387</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=387#p387"/>
		<title type="html"><![CDATA[StereoPi 0.9 2 pins instead of 3]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=387#p387"><![CDATA[
Hi.<br>I just got my StereoPi, bought on CrowdSupply. I'm following the instructions on setting up my StereoPi Standard Edition. So, according wiki.stereopi <br>we have a picture <img src="https://wiki.stereopi.com/images/thumb/3/3c/Stereopi-top-noted-1280.png/1200px-Stereopi-top-noted-1280.png" class="postimage" alt="Image"> Where there are 3 pins under "A" and I have to install jumper. But, I've got StereoPi v0.9 and on "A" place I have only 2 pins and subscribed as USB SLAVE. What I have to do, in order to power up the stereoPi, and install Linux on eMMC for Raspberry Pi Compute Module 3+ (no lite version)?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=142">dionis.moldovan</a> — Tue Jul 02, 2019 8:56 am</p><hr />
