	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1128" />
	<updated>2021-04-20T09:46:56+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1128</id>
		<author><name><![CDATA[dragon]]></name></author>
		<published>2021-04-20T09:46:56+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2652#p2652</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2652#p2652"/>
		<title type="html"><![CDATA[Re: Raspberry reboot yourself]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2652#p2652"><![CDATA[
And I also have problem with wifi-dongle. It doesn't connect to some WiFi-network. But if I use RP 3B+, it connect good to network.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=346">dragon</a> — Tue Apr 20, 2021 9:46 am</p><hr />
		<updated>2021-04-19T20:29:22+00:00</updated>
		<published>2021-04-19T20:29:22+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2648#p2648</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2648#p2648"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2648#p2648"><![CDATA[
I use power bank Xiaomi 5.1V 2.4A. Power adapter 5V 2A.<br>Maybe the power bank voltage is dropping when raspberry have high load?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=346">dragon</a> — Mon Apr 19, 2021 8:29 pm</p><hr />
		<updated>2021-04-19T19:32:48+00:00</updated>
		<published>2021-04-19T19:32:48+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2647#p2647</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2647#p2647"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2647#p2647"><![CDATA[
Hey Dragon,<br>In 99% of cases of a reboot under high load, the reason is the lack of power of the power source (not enough current provided).<br>We recommend using at least 2A PSU (and Raspberry says at least 2.4A). It is better to get a well-known (branded) power supply, as with the no-name and declared 3A you can actually get 1A current only.<br>As for the battery - if you are using the power bank, please choose the version with the 2.4A output. The default output current for a small USB power bank is just 1A. It's enough for the regular operation of the Pi, but not enough for the high load (like shooting and recording huge images).<br>Which PSU and battery are you using?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon Apr 19, 2021 7:32 pm</p><hr />
		<updated>2021-04-18T15:58:09+00:00</updated>
		<published>2021-04-18T15:58:09+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2643#p2643</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2643#p2643"/>
		<title type="html"><![CDATA[Raspberry reboot yourself]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2643#p2643"><![CDATA[
Raspberry reboot yourself when I take a series of shots with capture_continuous. It can take a few pictures, then reboot. Or can reboot immediatly after start script. <br>GPU memory 256, StereoPi with CM3+.<br>I use raspbian desktop. Maybe this is a big load for raspberry?<br>This could be because it is powered by a battery. But I connected it to the power adapter - everything is the same (I tried it 1 time).<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=346">dragon</a> — Sun Apr 18, 2021 3:58 pm</p><hr />
