	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1113" />
	<updated>2021-10-28T13:53:11+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1113</id>
		<published>2021-10-28T13:53:11+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2901#p2901</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2901#p2901"/>
		<title type="html"><![CDATA[Re: mouse and keyboard not working]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2901#p2901"><![CDATA[
Hi Shigure,<br>For the StereoPi v2, you can use any method of power, and this does not affect the USB status.<br>But CM4 requires this row to be added to /boot/config.txt to enable the USB hub:<div class="codebox"><p>Code: </p><pre><code>dtoverlay=dwc2,dr_mode=host</code></pre></div><strong class="text-strong">PLEASE NOTE: </strong>this row is already added to config.txt files in our SLP2 and OpenCV images. You need to add it only if you are using the new stock RaspiOS image. Here is our Wiki note for this: <a href="https://wiki.stereopi.com/index.php?title=StereoPi_v2_Quick_Start_Guide#How_to_use_stock_RaspiOS_with_the_StereoPi_v2" class="postlink">How to use stock RaspiOS with the StereoPi v2</a>.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Thu Oct 28, 2021 1:53 pm</p><hr />
		<author><name><![CDATA[Shigure]]></name></author>
		<updated>2021-10-23T16:22:39+00:00</updated>
		<published>2021-10-23T16:22:39+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2897#p2897</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2897#p2897"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2897#p2897"><![CDATA[
Hi. <br>I have StereoPi v2.02 and my mouse and keyboard are not working from USB-A too.<br>Also I have tryed connected it throw USB 3.0 Hub with external power, but still not work.<br><br>Now power supply from micro-USB (2700 mA) <br>Must I using JST connector?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=991">Shigure</a> — Sat Oct 23, 2021 4:22 pm</p><hr />
		<author><name><![CDATA[MIKES]]></name></author>
		<updated>2021-04-07T14:36:40+00:00</updated>
		<published>2021-04-07T14:36:40+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2607#p2607</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2607#p2607"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2607#p2607"><![CDATA[
Yes, it worked that way. <br>Thank you for your help<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=768">MIKES</a> — Wed Apr 07, 2021 2:36 pm</p><hr />
		<updated>2021-04-03T05:10:35+00:00</updated>
		<published>2021-04-03T05:10:35+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2594#p2594</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2594#p2594"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2594#p2594"><![CDATA[
"stereopi starter kit" sounds like the v1.<br>In v1, you "have to" power the stereopi with the white JST connector. If you power it with the micro USB, it enters in device mode and the USB-A connectors are then disabled.<br>Maybe it is what happens in your case.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=101">stereomaton</a> — Sat Apr 03, 2021 5:10 am</p><hr />
		<updated>2021-04-02T16:49:49+00:00</updated>
		<published>2021-04-02T16:49:49+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2592#p2592</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2592#p2592"/>
		<title type="html"><![CDATA[mouse and keyboard not working]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2592#p2592"><![CDATA[
Hi everyone, uim starting a new university project and i got the stereopi starter kit, i installed raspbien whith opencv from stereowiki and my mouse and keyboard are not working.<br>I have tryed a simplest mouse wired and a wireless mouse and nothing works.<br>If anyone can give me some tips i would be gratefull<br><br>Good luck to all your projects<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=768">MIKES</a> — Fri Apr 02, 2021 4:49 pm</p><hr />
