	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1112" />
	<updated>2021-03-31T06:14:09+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1112</id>
		<published>2021-03-31T06:14:09+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2586#p2586</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2586#p2586"/>
		<title type="html"><![CDATA[Re: StereoPI V2 - how to trigger a flash light?]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2586#p2586"><![CDATA[
You probably want to add electronics between the GPIO and the flash. Depending on the schematics I found online, they add either optocoupler (that I would personally prefer as it isolates the two sides), transistor, thyristor or even sometimes triac. You might add an ne555 to add an adjustable delay if you want.<br><br>To enable it in the kernel, realizator, maybe a device tree overlay would be more pertinent than a new custom dt-blob.bin<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=101">stereomaton</a> — Wed Mar 31, 2021 6:14 am</p><hr />
		<updated>2021-03-30T13:14:52+00:00</updated>
		<published>2021-03-30T13:14:52+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2585#p2585</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2585#p2585"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2585#p2585"><![CDATA[
Hey Mr. Burns,<br>Hmmm, I found that the flash driver is enabled in the Raspberry OS kernel for a long time (related <a href="https://www.raspberrypi.org/forums/viewtopic.php?f=43&amp;t=83484" class="postlink">Raspberry forum thread</a>, stereoscopy-related).<br>So the only thing we need to do is to assign a pin for the flash support in our dt-blob.bin, and it should work out of the box. We should think of how to avoid the pin functions conflict in this case. Maybe we'll create a special dt-blob.bin to use for the flash function.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Tue Mar 30, 2021 1:14 pm</p><hr />
		<author><name><![CDATA[mr.burns]]></name></author>
		<updated>2021-03-29T16:56:03+00:00</updated>
		<published>2021-03-29T16:56:03+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2584#p2584</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2584#p2584"/>
		<title type="html"><![CDATA[StereoPI V2 - how to trigger a flash light?]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2584#p2584"><![CDATA[
Hi,<br><br>I ordered StereoPI V2, and I want to be well prepared if shipment arrives <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_wink.gif" width="15" height="17" alt=";-)" title="Wink">.<br><br>Since I want to use the StereoPI V2 only for still images I need a flash for low light situations.<br>Is there any way to trigger a flash?<br><br>Typical flash shoes have one middle contact which is to pull to ground to trigger the flash. Can I do that with an GPIO of StereoPI V2?<br>Since it is necessary that flash fires if both cams have shutter open the timing is key. Can the flash trigger timepoint be adjusted by software?<br><br>Thanks...<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=759">mr.burns</a> — Mon Mar 29, 2021 4:56 pm</p><hr />
