	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1111" />
	<updated>2021-09-06T07:31:14+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1111</id>
		<published>2021-09-06T07:31:14+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2790#p2790</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2790#p2790"/>
		<title type="html"><![CDATA[Re: Micro 4/3 lenses on the HQ Camera module]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2790#p2790"><![CDATA[
Stereonova, the baseline of the HQ metal housing is 65mm.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon Sep 06, 2021 7:31 am</p><hr />
		<author><name><![CDATA[stereonova]]></name></author>
		<updated>2021-09-05T08:51:52+00:00</updated>
		<published>2021-09-05T08:51:52+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2786#p2786</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2786#p2786"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2786#p2786"><![CDATA[
Can you state the exact length of the baseline so I can decide if the CNC mount is suitable for my projects. Thanks.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=969">stereonova</a> — Sun Sep 05, 2021 8:51 am</p><hr />
		<updated>2021-03-29T12:46:20+00:00</updated>
		<published>2021-03-29T12:46:20+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2576#p2576</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2576#p2576"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2576#p2576"><![CDATA[
Hi Wmedia,<br>If you can do a kind of draft drawings - it will be great! We can look at the available options.<br>As I know, the default HQ housing (and the native HQ camera metal setup) are designed for the CS optics, which has 12.526 flange focal distance (source - <a href="https://en.wikipedia.org/wiki/C_mount" class="postlink">Wiki</a>). This means you can use a couple of C/CS mount adaptors, which are, in fact, just increases the distance between the sensor and the backside of the lens. These adapters are inexpensive and have a variable length. Can this approach work for you?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon Mar 29, 2021 12:46 pm</p><hr />
		<author><name><![CDATA[wmedia]]></name></author>
		<updated>2021-03-28T01:43:42+00:00</updated>
		<published>2021-03-28T01:43:42+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2573#p2573</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2573#p2573"/>
		<title type="html"><![CDATA[Micro 4/3 lenses on the HQ Camera module]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2573#p2573"><![CDATA[
I wish to use my m4/3 lenses on the HQ Camera module, but there is no m4/3 to C-mount adapters on the marked. (only the wrong way)<br><br>The reason for a non existent m4/3 to C-mount adapter is:<br>The flange distance on a C-mount is 17.526 mm and the flange distance on m4/3 is 19.25 mm. This gives a play of 1,724mm, and the problem is that the depth of the bayonet is 4mm. So the C-mount needs to be 2,276mm inside the bayonet of the m4/3 lens.<br><br>I did order the CNC machining metal housing. So the best solution is to CNC machining a new custom frontplate for a m4/3 bayonet mount with the correct flange distance. I have a strong wish that the StereoPi project will consider this option.<br><br>Maybe anyone have som good ideas?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=765">wmedia</a> — Sun Mar 28, 2021 1:43 am</p><hr />
