	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1092" />
	<updated>2021-03-15T09:53:27+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1092</id>
		<published>2021-03-15T09:53:27+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2517#p2517</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2517#p2517"/>
		<title type="html"><![CDATA[Re: snapshot two pictures in the same vsync]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2517#p2517"><![CDATA[
Wasfan, this is the way we use in our OpenCV code. We capture a stereoscopic pair and then split it into left and right images. Our experience says this is the most comfortable way instead of working with separate images, and also the only way for stereoscopic video processing.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon Mar 15, 2021 9:53 am</p><hr />
		<author><name><![CDATA[wasfan]]></name></author>
		<updated>2021-03-14T10:36:34+00:00</updated>
		<published>2021-03-14T10:36:34+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2512#p2512</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2512#p2512"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2512#p2512"><![CDATA[
hi<br>some deep learning model need pitcures to trained by this way.<br>i will split pic by cv , thx<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=738">wasfan</a> — Sun Mar 14, 2021 10:36 am</p><hr />
		<updated>2021-03-09T12:00:24+00:00</updated>
		<published>2021-03-09T12:00:24+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2492#p2492</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2492#p2492"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2492#p2492"><![CDATA[
Yes, you can. You just run tewo image capture commands.<br>Please note, that in the stereoscpic mode images are synced by default. But if you are taking them separately, system does not know you need to synchronize them. In this case the direct sensors sync can help you.<br>I'm curious, why do you need two independent images, and why splitting them after capturing a frame does not works for you?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Tue Mar 09, 2021 12:00 pm</p><hr />
		<updated>2021-03-09T11:15:14+00:00</updated>
		<published>2021-03-09T11:15:14+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2491#p2491</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2491#p2491"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2491#p2491"><![CDATA[
Hi <br>when i snapshot , i get a jpg that merged by left and right <br>can i get pictures individually ? left.jpg , right.jpg ?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=738">wasfan</a> — Tue Mar 09, 2021 11:15 am</p><hr />
		<updated>2021-03-05T17:00:06+00:00</updated>
		<published>2021-03-05T17:00:06+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2489#p2489</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2489#p2489"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2489#p2489"><![CDATA[
Hi wasfan,<br>That’s the key point of the stereoscopy - to get both images at the same time. <br>You can use default software synchronization (a few milliseconds precision). Or advanced hardware sync with nanosecond precision. HQ cameras has this feature out-of-the-box, as I mentioned in our last update: <a href="https://www.crowdsupply.com/stereopi/stereopi-v2/updates/a-look-at-the-features-and-advantages-of-the-new-hq-based-stereopi" class="postlink">https://www.crowdsupply.com/stereopi/st ... d-stereopi</a><p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Fri Mar 05, 2021 5:00 pm</p><hr />
		<updated>2021-03-05T11:45:24+00:00</updated>
		<published>2021-03-05T11:45:24+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2488#p2488</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2488#p2488"/>
		<title type="html"><![CDATA[snapshot two pictures in the same vsync]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2488#p2488"><![CDATA[
Hi<br>  could i get two pictures ( left, right) at the same time ( the same vsync)<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=738">wasfan</a> — Fri Mar 05, 2021 11:45 am</p><hr />
