	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1089" />
	<updated>2021-02-26T13:33:21+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1089</id>
		<published>2021-02-26T13:33:21+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2457#p2457</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2457#p2457"/>
		<title type="html"><![CDATA[Re: separate gains/exposure times?]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2457#p2457"><![CDATA[
HI ori333,<br>To say briefly - yes!<br>You can run to instances of raspivid, each working with its own camera. Ans set the parameters you need for each camera.<br>You can also do this by accessing video devices over VFL.<br>Please note, that in this case, you are working with 2 independent cameras, but not in the stereoscopic mode. So software sync will not work here. If you need sync - you have to use hardware features (like XVC syncing or synchronizing cameras' oscillators).<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Fri Feb 26, 2021 1:33 pm</p><hr />
		<author><name><![CDATA[ori333]]></name></author>
		<updated>2021-02-25T23:21:11+00:00</updated>
		<published>2021-02-25T23:21:11+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2451#p2451</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2451#p2451"/>
		<title type="html"><![CDATA[separate gains/exposure times?]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2451#p2451"><![CDATA[
Can the two cameras have separate gains/exposure times?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=723">ori333</a> — Thu Feb 25, 2021 11:21 pm</p><hr />
