	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1081" />
	<updated>2021-02-24T23:42:56+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1081</id>
		<published>2021-02-24T23:42:56+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2439#p2439</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2439#p2439"/>
		<title type="html"><![CDATA[Re: USB Flash Drive]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2439#p2439"><![CDATA[
I'm glad it works for you! <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":-)" title="Smile"><p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Wed Feb 24, 2021 11:42 pm</p><hr />
		<author><name><![CDATA[Rigsson]]></name></author>
		<updated>2021-02-24T23:28:15+00:00</updated>
		<published>2021-02-24T23:28:15+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2437#p2437</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2437#p2437"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2437#p2437"><![CDATA[
<blockquote class="uncited"><div>Hi Rigsson,<br>We have exactly the same question here: <a href="https://forum.stereopi.com/viewtopic.php?f=10&amp;t=64" class="postlink">Change the path for video recordings?</a><br>Hope this helps!</div></blockquote>Thank you. That did the trick.<br>For any others who might happen to fall into this thread I had to change the mount point to /dev/sda1<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=295">Rigsson</a> — Wed Feb 24, 2021 11:28 pm</p><hr />
		<updated>2021-02-16T15:53:12+00:00</updated>
		<published>2021-02-16T15:53:12+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2432#p2432</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2432#p2432"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2432#p2432"><![CDATA[
Hi Rigsson,<br>We have exactly the same question here: <a href="https://forum.stereopi.com/viewtopic.php?f=10&amp;t=64" class="postlink">Change the path for video recordings?</a><br>Hope this helps!<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Tue Feb 16, 2021 3:53 pm</p><hr />
		<updated>2021-02-15T21:24:24+00:00</updated>
		<published>2021-02-15T21:24:24+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2430#p2430</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2430#p2430"/>
		<title type="html"><![CDATA[USB Flash Drive]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2430#p2430"><![CDATA[
Hello all,<br>I just finished assembling a starter kit in to a case and I would like to store the photos to an external flash drive instead of the internal SD card. I added a panel mount USB extender to bring the connections to the outside of the case. When I plug in the flash drive its activity light blinks a couple times so it powers up and is (I assume) recognized. On a Pi 3b (Raspbian) I see the drive as a subfolder to the media folder but on the Stereo Pi all I see is the photo folder. Does S.L.P. mount to a different path than Raspbian? And if so what is the path?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=295">Rigsson</a> — Mon Feb 15, 2021 9:24 pm</p><hr />
