	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1078" />
	<updated>2021-02-04T14:04:55+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1078</id>
		<published>2021-02-04T14:04:55+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2425#p2425</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2425#p2425"/>
		<title type="html"><![CDATA[Re: Snapchat StereoPi]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2425#p2425"><![CDATA[
Hi Frivy,<br>To say briefly, StereoPi is compatible with all Raspberry Pi compatible cameras. So you can try to find Pi camera with the features you need.<br>As for the twisted pair style - I was not able to find any Pi-compatible flexible cable ( like this one <a href="https://www.mobius-actioncam.com/store/products/mobius-8-inch-lens-extension-cable/" class="postlink">for Mobius</a>). You can try to DIY this cable, but CSI-2 is a high-frequency bus, and you can face some troubles with not good enough cables. With the "not ideal" cable camera will be detected, but data transfer will fail.<br>Smaller cameras: take a look at the Pi Zero Spy cameras. They are really tiny. But it would help if you did an adaptor to connect a small PiZero camera ribbon cable (22 pins) to the classic 15-pin camera connector used on the StereoPi.<br>StereoPi also supports some modules not supported by classic Raspberry Pi. You can look at <a href="https://soho-enterprise.com" class="postlink">https://soho-enterprise.com</a> and Arducam solutions too. Please note that all IMX219 and IMX477-based cameras should work out-of-the-box, but for other sensors, you need to do a tricky driver install process (and it's a headache).<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Thu Feb 04, 2021 2:04 pm</p><hr />
		<author><name><![CDATA[Frivy]]></name></author>
		<updated>2021-02-04T13:20:50+00:00</updated>
		<published>2021-02-04T13:20:50+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2424#p2424</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2424#p2424"/>
		<title type="html"><![CDATA[Snapchat StereoPi]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2424#p2424"><![CDATA[
I'm considering removing all the hardware from a v1 (older) Snapchat spectacles' frame and installing the cameras from a SterePi.  The idea is to make 3d video glasses.  <br><br>Does anyone know of cameras and cables that are StereoPi compatible and are small enough for this application.   For example using ribbon cables is not a good option.  <br><br>Are twisted pair style camera cables available?<br><br>Are smaller cameras compatible with StereoPi available?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=708">Frivy</a> — Thu Feb 04, 2021 1:20 pm</p><hr />
