	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1054" />
	<updated>2021-01-25T11:33:39+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1054</id>
		<published>2021-01-25T11:33:39+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2407#p2407</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2407#p2407"/>
		<title type="html"><![CDATA[Re: Board detects only 1 camera]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2407#p2407"><![CDATA[
Hi stnz,<br>Sorry for my late reply.<br>Could you please write me an email to my nickname @gmail.com? I think that the board replacement is a good solution here.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon Jan 25, 2021 11:33 am</p><hr />
		<author><name><![CDATA[stnz]]></name></author>
		<updated>2021-01-04T14:00:25+00:00</updated>
		<published>2021-01-04T14:00:25+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2389#p2389</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2389#p2389"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2389#p2389"><![CDATA[
I now tried to use an older version of Raspbian, to see if maybe the problem comes from a recent change in software / kernel, but the problem persists. Do you have any other advice on what I could do? Thank you!<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=674">stnz</a> — Mon Jan 04, 2021 2:00 pm</p><hr />
		<updated>2020-12-30T13:38:41+00:00</updated>
		<published>2020-12-30T13:38:41+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2388#p2388</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2388#p2388"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2388#p2388"><![CDATA[
Hi Realizator,<br><br>thanks a lot for the reply! I first checked the cameras and cables. I swapped the ports so that I can sort that out. No matter which cable/camera is on port 0 and on port 1 I get a picture when running <div class="codebox"><p>Code: </p><pre><code>raspivid -cs 0</code></pre></div> and I get error 3 when running <div class="codebox"><p>Code: </p><pre><code>raspivid -cs 1</code></pre></div>.<br>As to your questions:<br>1. I am using two identical V2.1 NOIR cameras<br>2. The result is<div class="codebox"><p>Code: </p><pre><code>supported=2 detected=1</code></pre></div> (no matter which cam is on which port).<br>Thank you very much for your support!<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=674">stnz</a> — Wed Dec 30, 2020 1:38 pm</p><hr />
		<updated>2020-12-28T14:41:50+00:00</updated>
		<published>2020-12-28T14:41:50+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2387#p2387</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2387#p2387"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2387#p2387"><![CDATA[
Hello Stnz,<br>Our experience says, that in 97% cases this problem means a physical connection issue (i.e. camera ribbon cable issue, or a "Sunny" connector on the camera PCN).<br>Could you please tell us:<br>1. Which camera model you are using?<br>2. What is the result of this command:<div class="codebox"><p>Code: </p><pre><code>sudo vcgencmd get_camera</code></pre></div><p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon Dec 28, 2020 2:41 pm</p><hr />
		<updated>2020-12-23T11:45:21+00:00</updated>
		<published>2020-12-23T11:45:21+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2386#p2386</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2386#p2386"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2386#p2386"><![CDATA[
Hi community,<br><br>I just experienced the very same problem. While first dual camera has been working, it now cannot detect the second camera anymore after a few days. I also swapped cameras (and the ribbon cables), but still only the first camera slot is working. Reflashed RaspberryOS and copied the blob file, but still, the problem persists. What else can I do?<br><br>Thanks for your help!<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=674">stnz</a> — Wed Dec 23, 2020 11:45 am</p><hr />
		<updated>2020-12-21T14:58:34+00:00</updated>
		<published>2020-12-21T14:58:34+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2377#p2377</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2377#p2377"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2377#p2377"><![CDATA[
Hi season2episode3,<br>Wow, it's a pity you have this trouble with your board.<br>Am I got you right, that after swapping cameras, you can get an image, but from the single CSI connector only? <br>Please also look into the non-working connector, as sometimes a small dust or piece of plastic causing this issue.<br><br>I wrote you an email. Please answer <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":-)" title="Smile"><p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon Dec 21, 2020 2:58 pm</p><hr />
		<author><name><![CDATA[season2episode3]]></name></author>
		<updated>2020-12-21T01:13:30+00:00</updated>
		<published>2020-12-21T01:13:30+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2376#p2376</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2376#p2376"/>
		<title type="html"><![CDATA[Board detects only 1 camera]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2376#p2376"><![CDATA[
Hey StereoPi community <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":)" title="Smile"> <br><br>I recently stopped being able to capture stereo video from my stereopi, only one of the two cameras work. This issue persists after swapping camera positions as well as after switching from V2 cameras to V1 cameras. <br><div class="codebox"><p>Code: </p><pre><code>$ sudo vcgencmd get_camerasupported=2 detected=1$ raspistill -cs 0 -v &lt;works correctly&gt;$ raspistill -cs 1 -vmmal: Could not select camera : error 3mmal: main: Failed to create camera componentmmal: Failed to run camera app. Please check for firmware updates</code></pre></div>Reading the rest of this forum indicates this is a hardware problem that needs a replacement board. (e.g., <a href="https://forum.stereopi.com/viewtopic.php?f=5&amp;t=1029" class="postlink">this thread</a>) Can anyone from the team confirm?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=669">season2episode3</a> — Mon Dec 21, 2020 1:13 am</p><hr />
