	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/1029" />
	<updated>2020-11-07T05:57:00+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/1029</id>
		<author><name><![CDATA[ammarburg]]></name></author>
		<published>2020-11-07T05:57:00+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2353#p2353</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2353#p2353"/>
		<title type="html"><![CDATA[Re: Camera 1 not detected]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2353#p2353"><![CDATA[
Hate to harp on this, but I have not had any communication from Crowd Supply.   Is a replacement still in the works?<br><br>Thanks!<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=621">ammarburg</a> — Sat Nov 07, 2020 5:57 am</p><hr />
		<updated>2020-10-23T09:28:06+00:00</updated>
		<published>2020-10-23T09:28:06+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2306#p2306</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2306#p2306"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2306#p2306"><![CDATA[
Hi ammarburg,<br>Replacement confirmed by Crowd Supply, and they will ship it to you in a few days!<br>I also replied to your email.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Fri Oct 23, 2020 9:28 am</p><hr />
		<updated>2020-10-23T04:56:30+00:00</updated>
		<published>2020-10-23T04:56:30+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2305#p2305</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2305#p2305"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2305#p2305"><![CDATA[
Hi Eugene,<br><br>Just confirming I replied to the email earlier this week.  Let me know if it didn't come through.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=621">ammarburg</a> — Fri Oct 23, 2020 4:56 am</p><hr />
		<updated>2020-10-18T12:28:02+00:00</updated>
		<published>2020-10-18T12:28:02+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2293#p2293</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2293#p2293"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2293#p2293"><![CDATA[
Hello ammarburg ,<br>Yes, the forum is the right place to go <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":-)" title="Smile"><br>Sorry for this issue with your board. I see you did a lot of troubleshooting steps. If you have this error with the "-cs 0" option in both cases (before and after camera swap), then it looks like a second CSI-2 connector issue. I can suggest you a board replacement.<br><br>I sent you an email (to the address you used to register on this forum). Please answer.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Sun Oct 18, 2020 12:28 pm</p><hr />
		<updated>2020-10-16T21:46:36+00:00</updated>
		<published>2020-10-16T21:46:36+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2290#p2290</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2290#p2290"/>
		<title type="html"><![CDATA[Camera 1 not detected]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2290#p2290"><![CDATA[
Hi all,<br><br>I feel bad using the forum as a help ticketing system, but seems to be the way to go.<br><br>I have a v0.9 Stereopi from the original CrowdSupply buy which I'm finally trying to get going.   I have tried both the  v0.2.3 SLP and a current Raspbian install with the dt-blob.  Cameras in all cases are Raspi Cam V2 NOIR,  <br><br> In both cases:<br><br>1. "vcgencmd get_camera" returns "supported=2 detected=1"<br>2. "raspistill -cs 0 -v" appears successful, "raspistill -cs 1 -v" returns:<br><br>mmal: Could not select camera : error 3<br>mmal: main: Failed to create camera component<br>mmal: Failed to run camera app. Please check for firmware updates<br><br>3. I've swapped the (camera+cable) sets and had the same behavior.<br><br>Further options for debugging?   <br><br>Many thanks, everyone.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=621">ammarburg</a> — Fri Oct 16, 2020 9:46 pm</p><hr />
