	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/100" />
	<updated>2020-02-25T07:54:17+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/100</id>
		<published>2020-02-25T07:54:17+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1667#p1667</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1667#p1667"/>
		<title type="html"><![CDATA[Re: 1.44&quot; TFT screen Waveshare]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1667#p1667"><![CDATA[
Hi MauriceCyril,<br>You see, installation of this screen has no any problems, that's why we did not post any additional guides. The only difficulty I found was incorrect settings in the original guide, so I've posted second link to the RPi forum with the fix.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Tue Feb 25, 2020 7:54 am</p><hr />
		<author><name><![CDATA[MauriceCyril]]></name></author>
		<updated>2020-02-24T23:45:07+00:00</updated>
		<published>2020-02-24T23:45:07+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1666#p1666</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1666#p1666"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1666#p1666"><![CDATA[
Thanks so much will check them out. I thought there was a new consolidated guide that I was missing.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=351">MauriceCyril</a> — Mon Feb 24, 2020 11:45 pm</p><hr />
		<updated>2020-02-21T09:00:33+00:00</updated>
		<published>2020-02-21T09:00:33+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1657#p1657</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1657#p1657"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1657#p1657"><![CDATA[
Hi MauriceCyril,<br>At the very beginning of this post there are two links for the manual with all the steps you need. <br>Do you have any problems while installing? Which Raspbian image you're using for that?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Fri Feb 21, 2020 9:00 am</p><hr />
		<updated>2020-02-21T03:22:53+00:00</updated>
		<published>2020-02-21T03:22:53+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1655#p1655</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1655#p1655"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1655#p1655"><![CDATA[
Hi everyone, is there an updated guide on how to set this screen up with the stereopi?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=351">MauriceCyril</a> — Fri Feb 21, 2020 3:22 am</p><hr />
		<updated>2019-06-29T10:35:58+00:00</updated>
		<published>2019-06-29T10:35:58+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=381#p381</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=381#p381"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=381#p381"><![CDATA[
<blockquote class="uncited"><div>I'll try to do it solder-less</div></blockquote>Lots of people use this kind of jumper wires for prototyping [first link, not a recommandation]<br><a href="https://www.amazon.com/MCIGICM-40Pin-Breadboard-Jumper-Dupont/dp/B07PLZC26F/" class="postlink">https://www.amazon.com/MCIGICM-40Pin-Br ... 07PLZC26F/</a><p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=101">stereomaton</a> — Sat Jun 29, 2019 10:35 am</p><hr />
		<updated>2019-06-26T10:52:28+00:00</updated>
		<published>2019-06-26T10:52:28+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=373#p373</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=373#p373"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=373#p373"><![CDATA[
<blockquote class="uncited"><div>Looks promising, although I think it will be difficult to package this nicely with my stereopi. Probably requires new case or add it to the outside of existing case with 14 soldered wires <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_wink.gif" width="15" height="17" alt=";)" title="Wink"></div></blockquote>I'll try to do it solder-less, and will put my solution here. <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":-)" title="Smile"><p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Wed Jun 26, 2019 10:52 am</p><hr />
		<author><name><![CDATA[stereomii]]></name></author>
		<updated>2019-06-25T12:30:57+00:00</updated>
		<published>2019-06-25T12:30:57+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=368#p368</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=368#p368"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=368#p368"><![CDATA[
<blockquote class="uncited"><div>I've got one of these <a href="http://wiki.stereopi.com/files/stereopi-tft-screen-waveshare-1-44.jpeg" class="postlink">tiny funny screens</a> <br>.............<br>Looks like new guides are coming <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":-)" title="Smile"></div></blockquote>Looks promising, although I think it will be difficult to package this nicely with my stereopi. Probably requires new case or add it to the outside of existing case with 14 soldered wires <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_wink.gif" width="15" height="17" alt=";)" title="Wink"><p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=93">stereomii</a> — Tue Jun 25, 2019 12:30 pm</p><hr />
		<updated>2019-06-21T12:51:11+00:00</updated>
		<published>2019-06-21T12:51:11+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=355#p355</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=355#p355"/>
		<title type="html"><![CDATA[1.44&quot; TFT screen Waveshare]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=355#p355"><![CDATA[
I've got one of these <a href="http://wiki.stereopi.com/files/stereopi-tft-screen-waveshare-1-44.jpeg" class="postlink">tiny funny screens</a> <br>So after following <a href="https://pi0cket.com/tiny-software-for-tinypi/#more-99" class="postlink">this manual</a> with <a href="https://www.raspberrypi.org/forums/viewtopic.php?t=207627#p1284549" class="postlink">this fix</a> I got this result:<br><br><img src="https://wiki.stereopi.com/files/stereopi-tft-screen-waveshare-1-44.jpeg" class="postimage" alt="Image"><br><br>Looks like new guides are coming <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":-)" title="Smile"><p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Fri Jun 21, 2019 12:51 pm</p><hr />
