Live stream into Skybox on Oculus Go
Gol
Post by Gol »
I made live stream into Skybox application (available on Oculus Go/Quest). Here is an update file for StereoPi
stereopi-0.2.1.tar.gz
(2.18 MiB) Downloaded 400 times
Just install this update on StereoPi. After reboot, turn on Oculus Go, run Skybox video player, go into "Airscreen", press "Search device" and click on "STEREO-PI". "Livestream RTSP" works only if RTSP enabled in StereoPi config. Better to use "Livestream MPEG-TS", latency is much less.
Here is a video demo
My Skybox server source code is here https://github.com/virt2real/skybox-server
Re: Live stream into Skybox on Oculus Go
Gol, thank you for your code! But looks like I didn't yet added to Wiki updates installation procedure for S.L.P. image... I 'll add it tomorrow, I promise! :)
Looks like I've already added Update description in our Wiki. It is at the end of this section.
So for installing this update with the Skybox player support, you can use this guide.
wildag
Post by wildag »
Is there any way to get Skybox to show "fullscreen"?
It is better to ask Sergey. AFAIK no...
By the way, here is our Skybox protocol hack description.
Gol
Post by Gol »
wildag wrote:
Fri May 17, 2019 1:24 pm
Skybox not needed for fullscreen. Just use our app viewtopic.php?f=10&t=20
